Trailer brakes
Patriot Blue
Feb 6, 2021
Does the new Ram2500 come with trailer brakes or do I need to install them myself for towing?
Gondul
Prince of Pintops
Mar 10, 2019
Brake Controller depends on trim/package... IIRC some of the lower trims/packages do not come with one.
Should be able to check your sheet and see if it is included
Limey
Feb 26, 2021
Your signature shows 2021 2500 Bighorn ordered.
If that is the truck you are asking about then, yes it has an integrated brake controller.
Patriot Blue
Feb 6, 2021
Thx , men. I was thinking so but I dont have the truck now, and didn't see where that is indicated
MooneyFWD
Dec 11, 2020
Am I correct that the wiring is there on all of the trucks? I seem to remember that all you need to do is to buy the actual switch thingy if it wasn't included.
Depends you can go aftermarket there is a connector to do plug and play but if adding the oem style you will need a dealer flash or alfa obd to enable it as it is integrated in the trucks bcm but the connector is there to my understanding
