texas.yankee
Mar 4, 2019
So looked under my truck and it looks like the trailer pressure sensor connection is there. Its the same 4 wire plug in the same location mentioned in the diagram i posted above. Hopefully the trailer tire pressure module will simply be a plug and play item.
According to that TFL article it will require a flash so at the very least, a dealership will likely have to be involved for software.
D
Deleted member 80
Guest
I have been down this road with Chrysler before, and I will be very surprised if there is more than ZERO support for early buyers on this matter. They are likely to just wash their hands of it. I hope I'm wrong.
Gondul
Prince of Pintops
Mar 10, 2019
Seeing the 'issues' some early adopters had over on the 1500 forum, I agree 100%
Stumblefoot
Mar 5, 2019
I wonder when the Mopar trailer camera becomes available if it'll be as nightmarish as the TTPM is going to be?
Ron D.
Apr 17, 2019
Toledo, Ohio
regal2800 when did you order you truck , I ordered mine 2-8-19 , I looked for the trailer pressure sensor connection , not sure if I could see it.
Gondul
Prince of Pintops
Mar 10, 2019
None of the trucks so far have TTPMS... won't be released "early summer"....
RamPilot
Jun 23, 2019
I ordered my 3500 Dually, in mid June, expected by September. My order specifically purchased the trailer camera connection. No mention of TPMS though. BTW is it TPMS or TTPMS, I would really like the temperature info. Hoping my truck is standard with it.
The HOFF
Don't Hassel me
May 8, 2019
500Here is what’s in the brochure. I’m hoping mine has it. My sales rep said it’s in the towing pkg, if not they will paying for the upgrade.
texas.yankee
Mar 4, 2019
TPMS (
Your 3500 has a slightly different system than TPMS (tire pressure monitoring system). You actually have TPIS (tire pressure information system) which only tells you the pressure. It doesn't alert you when a pressure is low.
TTPMS is Trailer tire monitoring system.
HTH
thestuarts
Jun 10, 2019
TPMS is the Tire Pressure Monitoring System for the tires on the truck.
TTPMS is the Trailer Tire Pressure Monitoring System for the tires on the trailer.
This is the video where Jim Morrison, head of Ram brand FCA North America, and Rod Romain, Ram’s chief engineer of heavy-duty trucks, announce the TTPMS system:
The TTPMS is currently listed on the RAM 3500 capability page:
https://www.ramtrucks.com/2019/ram-3500/capability.html
The TPMS and TTPMS systems are listed on page 220 and 225 respectively of the owner's manual:
https://msmownerassets.z13.web.core.../en-us/Ram/2019/2500/RAM_2500_3500_OM_USA.pdf
thestuarts
Jun 10, 2019
Where did you get that brochure, the dealership?
thestuarts
Jun 10, 2019
As @Gondul recommended, get that in writing because The Fast Lane Truck contacted Ram about adding the TTPMS feature, but Ram said it won't be easy.
For those with the early build trucks without TTPM, getting the feature added back on won’t be as simple as a plug-and-play MOPAR kit either. "TTPM could be added but it would consist of vehicle configuration changes, software flashes, wiring, and module replacement,” said a Ram spokesman. “It can be done, but it is not a Mopar kit that’s plug and play.”"
The HOFF
Don't Hassel me
May 8, 2019
I’ll be hooking up to mine on Saturday and see. Sure hope so.
RamPilot
Jun 23, 2019
This is what my dealer told me today as well. My unit is expected in September and more then likely will not have TTPMS... I’m sad about that. When available it’s probably going to be an up charge for the option.
