Marcross1009
- Joined
- Sep 3, 2021
So I've been towing with my 21 3500 srw HO Cummins to tow a 40ft travel trailer (approx 11k) and noticed a lot of the time I am running 60mph or so on fairly flat land and with tow haul on it will not kick into 6th gear, if I accelerate to 65+ and then slow down it will shift and not downshift to 5th unless I slow below about 55(ish). I did try turning tow/haul off while cruising 60mph and it immediately shifted to 6th. Other than the exhaust braking, which is great btw, if I'm just cruising and not pulling hills or anything will it hurt the transmission to kick off tow haul so it will kick into 6th? I've checked and normal towing with tow haul the trans temperature sits between 150-170. I wasn't sure if it would heat up not in tow haul, which is why I haven't experimented more than turning it off once. I would like to get the extra mpgs but not at the cost of hurting the transmission. So will it hurt the transmission to tow not in tow/haul mode?
