Adding diesel?! Hahaha clear as day it’s full of fuelMoring check.View attachment 68805
Saw this this morning. They think I am adding it.View attachment 68812
That's hilarious! These really are some stoopid mofo's. I had my oil changed (2nd time in a month) last Wednesday, I drove 250 miles (4.5 engine hours) on Thursday (2 regens), and my dipstick looks like your dipstick after an overnight sit on Friday morning. I don't have the clever paint marks on my fill cap so I guess it's possible that someone added 2 qts of something for some reason. SMH.Moring check.View attachment 68805
That is crazy.Yeah I laugh when I saw that. I would say a piece of seal tap or something of the sorts that you couldn't set back to the original place would be a bit better or at least a scribe mark that I wouldn't notice lmao.
The mark on the cap is standard practice when an oil consumption test is being performed. I’m surprised they didn’t install an actual “do not tamper” sticker across the cap.
In this case, it’s more of an oil production test.
Your recently replaced DOC / DPF assembly (and everything else) in the downstream is likely ruined at this point. That includes the turbocharger whose bearings are unquestionably taking a hit from the reduction in oil viscosity and friction protection.
I would not be satisfied with anything less than a complete engine and emission replacement at this point.
If this keeps up, you’ll be at a tipping point and it will start consuming oil.
Quite a lot. Your CCV system is going to draft it over into the charge air first. Have you ever pulled the tube off of the intake side of the charger?How high of oil level and boost do you need to get it to come out the dip stick neck?
You should pull the tube off and take some pictures (for your own records) and our amusement.Nope can't say that I have.
I'm scheduled for a fuel system eval a week from Wednesday, I'll let y'all know what's what afterwards. At least my dealership mechanics are taking this seriously and not clowning me. Meanwhile, it's parked and won't be used until then.
That turbo looks gross. Def not normal.
