AZ Sooner
Looking for advice, I want to replace my factory 31 gallon fuel tank with a Titan 50 gallon or S&B 52 gallon. Anyone have issues with either of these brands?
Thank you for the infoFrom what I’ve read, most people are pretty happy with their Titan tanks. S&B has some bad reviews for documentation/parts missing when it showed up.
When I was in SoCal, I went to Aero Fuel tanks in Corona CA and they put a 48 on my Duramax Crew Cab. Had no problems with that one in 9 years of ownership
No problem. I’ll be following this. Wanted a Titan to go on the new truck… but wanted to get the truck first to see how far it’ll hang down.Thank you for the info
Great info, thank youI installed the Titan 55 Gallon tank in my 2019 Ram 3500 CCLB. Great product but make sure your installer follows the tank seal torque process exactly or you will very likely have a leak. Likely a big one, let’s just say my local gas station was not happy with the diesel fuel puddle I left them upon filling. Had my local Ram dealer do the install and they clearly didn’t follow the instructions.
Here is another recent thread on setting the fuel capacity in the BCM to get the DTE calc updated.
52 gal Titan fuel tank
I have a 2020 Ram 2500 4x4 6.7 diesel and I am thinking about changing the fuel tank out. I was told I might need the Alpha OBD when I do this to change settings for the tank. Any opinions would be appreciated. Thankshdrams.com
I believe the new Titan tanks have the locking ring similar to OEM/S&B now.I installed the Titan 55 Gallon tank in my 2019 Ram 3500 CCLB. Great product but make sure your installer follows the tank seal torque process exactly or you will very likely have a leak. Likely a big one, let’s just say my local gas station was not happy with the diesel fuel puddle I left them upon filling. Had my local Ram dealer do the install and they clearly didn’t follow the instructions.
Could be. I purchased mine about a year ago. Here is what the Titan tank seal clamping mechanism looked like on mine. If you don’t evenly torque all the bolts multiple times, then it will very likely leak as you can see in the picture.I believe the new Titan tanks have the locking ring similar to OEM/S&B now.
They actually did the install free for me (the first 2006 they did). Want to say it was 45 min to an hour for the install.What did they charge for the install? Im close to that shop...
That is exactly what I have on my 3500 although saying you have a 1,000 mile range made me startle! The 52 gallon tank increased my range for sure but because I only really have it filled when on a towing trip, and can only really use maybe 47 gallons before getting nervous enough to refill, my range is more like 500+ miles. Still, much better than the 280 miles the OEM tank would have provided when towing.Just installed a titan 52 gallon fuel tank on my 2021 Ram 2500 CCSB. Love it. Paid an installer and honestly I should have done it myself. Not bad at all. Updated the computer to recognized the new tank size best I could. So far about 1000 or so miles of range on a single tank.
Once the new tank is installed and totally filled does it make the truck lean a little because the added weight?
That is my only potential worry about going that direction. Fortunately I'm not a huge fatty and weigh 215lbs so that shouldn't add too much lean.
Yeah I wish we could get the 19.5 mpg when towing! My truck is used and will be used for towing about 75% of the time and I am good when I get 11 mpg.Most of my runs lately have been from TN to FL and back. During that time I was around that 47 gallon mark on refill and I had made the entire trip without stopping. Trip meter showed a little over 1000 miles traveled. I wasn't running super fast but pretty consistent.
Need to use AlfaOBD or AutoEnginuity with enhanced Chrysler option.How did you update the computer to compute DTE based on the new size?
Thank you.Need to use AlfaOBD or AutoEnginuity with enhanced Chrysler option.
Here is a reference on another post to update:
