Purchased a 2024 2500 laramie 6.4 Hemi. Door Sticker calls for 70 PSI on front and back on the OEM Transforce tires. The dealer set them at 70 psi but the ride seems stiff and bumps are harsh. I'm assuming the 70 psi sticker is for when the truck has a load. My Ram 1500 called for 36 PSI which was fine and I inflated to 50 when towing my travel trailer based on the tires I had. Does anyone know what low end PSI will trigger the tire low pressure alert on the dash? I'm thinking of dropping to 50 PSI and seeing hoe the tires wear when not towing any load.
Thanks
Thanks
