GBB
- Joined
- Jan 4, 2021
I was noticing some outside wear on my front passenger tire with no noticeable wear on driver front tire and a slight pull to the right although very slight. Turning loose of steering wheel truck would drift to the right. Truck has around 32,000 miles on it. Current tires are Falken Wildpeaks with around 15,000 miles on them. So decided to have an alignment done to Thuren specs. Printed out the specs and gave to the alignment tech and told him I wanted as close to these as you can get especially the toe-in. After alignment was done and getting on the road I noticed the steering felt a little lighter and there was no more pull to the right. Very pleased with the results and would highly recommend using the Thuren specs if getting an alignment done.
