Just wanted to give my experience on my 3500 with Thuren .5” coils with Thurens front boogie bumps which on the 19-23 rams they use sumos.
With .5” TF351 coils or stock these will give a harsher ride on bumps. This being that stock or the low lift coils do not provide the lift and spacing that is needed between bump stop mount and contact pad on the axle. For me it prevented the Thuren coils and Fox 2.0s to cycle and absorb the bumps as it would immediately start compressing the sumo.
I bought them as I’ve bottomed out a few times on big bumps with speed. So figured I’d try them out to help the harsh hit from the stock hard rubber bump stops.
Thuren was awesome with customer service as always. I talked to them about my situation and Andrew even went out and looked at a truck there with boogie bumps and ok’d cutting the first rib off to give some clearance before engaging the sumo while still having enough material to absorb the impact. But after measuring it would still only allow 1.5” and less clearance vs the 2.5”-3” clearance stock. So I will return them and stick with stock bumps.
