Thuren Alignment and common torque Specs
Alignment issues?
Tire wear?
Odd handling?
Use Thuren alignment specs.
  • 13-22_2500_3500_PW.pdf
Trooper
Dec 6, 2019
SoCal
Not sure the intent of question, I have Thuren alignment.
2.75" level springs and riding on Fox 2.5 Shocks, 35" on 18's 45/40 psi.
No alignment issues, runs straight as arrow
Outer tire wear has been an issue since new, but reduced after alignment, just rotate every 6k
Zero handling issues
Crusty old shellback
Apr 10, 2021
I have a '21 75th AE PW.
Swapped out to BFG 35s at 200 miles. Saw excessive wear on the outside edge at 3200 miles. Also had a bad vibration at 65 to 70 MPHs. Took the truck into get it aligned to the Thuren specs. Found out the alingment was out of factory specs when I got it.
So far, the vibration is gone. Wear verdict is still out.
Aligned the toe to .02 degrees, as close to zero as we could get.
Castor was set at 3.5 degrees. No real difference in handling. Does seem to turn in a little bit quicker, but that's all
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
I’m pretty sure @Brutal_HO was just putting that here for people to find easier
No question. Sticky.
:rolleyes:
Added torque spec sheet compliments of @Rockcrawlerdude
Pitman Arm nut: 185 ft. lbs
index.php
