I optioned up my Bighorn to get a better payload capability, 6th person seating, and save over $10K from the Laramie.2500 is the way to go for what you say you want. Always kind of wonder why people start with a mid level trim and option it up. Then you end up paying almost as much as if you just went with the limited in the first place. I have the air suspension and it gives a great ride. And more importantly, I am always level when towing. IMHO it is a great option.
Given your criteria no way I'd opt for the more complicated eTorque equipped 1500 for the same money as a more capable 2500 truck. If adverse weather conditions are a problem you won't go wrong with the PW either - easily the most capable truck I've ever owned (just make sure your tires are up to the task). The level 3 will be equivalent to the 1500 Limited as far as how nice the interior and everything else is. The LED projector headlights you will love as well.
If I was you I'd do the PW.
Strategy I used:Really great info folks! Appreciate all the input. I do have a volume dealer here (Koons Tysons Corner) and I am thinking you guys are correct in building what I want.
The Power Wagon diff is a locker but also a limited slip when not locked and it works fairly well. The only drawback I've found is that if one wheel has good traction (like on pavement) and the other is in mud or grass it tends to completely act like an open diff and spin the tire with no traction - however if both tires have less than optimal traction (like in snow) it works great. Its a helical style limited slip.One other question.... how much does a rear locker help vs ELSD in snow? More specifically driving steep hills, switchbacks on snow covered roads. From research, and what I found on our forums, I would lock the rear ahead of time as I start to climb the steepest parts of my trip. For those who know the area, I travel often to Snowshoe WV from DC Metro area. Very interesting ride with major elevation changes. Should having the locker be a necessity??
"An electronic-locking differential enables the driver to prepare the vehicle for anticipated slippage, effectively pre-locking the axle vs. waiting for the LSD to kick in. This can provide a higher degree of control to the driver, especially if in a situation where sudden vehicle movement due to loss of traction would be undesirable. I've not owned a vehicle with an e-locker, but I look forward to testing it in a 'sticky situation' sometime soon."
Definitely this. I also believe the 1500 and 2500 6'4" boxes are the same length, so maneuverability should be the same. I went with the 2500 Hemi as well just in case I get a big trailer down the road and ordering one was actually quite a bit cheaper than a similarly optioned 1500 last year when I ordered it. The only thing that I don't like about it is the bed being so damn high off the ground. It doesn't help that I am short, but it is a pain to get stuff in the back without having to jump in it each time. This may not be as big of a problem for an average sized personGiven the size of the trucks are so similar, I'd go 2500 for sure.
1500 Max width: 79.9", Max height: 77.5"
2500 Max width: 79.4", Max height: 80.2"
I saw a mega cab with air suspension at my local dealer that had just come off the truck. I was shock at how much lower it sat in the rear than a regular 2500. It was about as low as a 1500. Add the bed step and getting stuff in and out shouldn’t be to bad.Definitely this. I also believe the 1500 and 2500 6'4" boxes are the same length, so maneuverability should be the same. I went with the 2500 Hemi as well just in case I get a big trailer down the road and ordering one was actually quite a bit cheaper than a similarly optioned 1500 last year when I ordered it. The only thing that I don't like about it is the bed being so damn high off the ground. It doesn't help that I am short, but it is a pain to get stuff in the back without having to jump in it each time. This may not be as big of a problem for an average sized person
With rear Air suspension on the 2500 you can drop the open tailgate height 3"s by simply pushing a button on the dash. Very nice.I saw a mega cab with air suspension at my local dealer that had just come off the truck. I was shock at how much lower it sat in the rear than a regular 2500. It was about as low as a 1500. Add the bed step and getting stuff in and out shouldn’t be to bad.
I have a 3500 CTD CC long bed. If I could be in a 1500 I would. The 1500s are a lot more comfortable as a daily driver, have plenty of capacity and you can get a 6.4 bed. The hd truck is great but I wouldn’t have it if I didn’t need it. Great on the highway but pretty stiff on bumpy in town roads.I don't want to start a major debate here but when pricing out the following models, here is what I am getting:
1. 1500 Laramie, 6'4" box, V8 E-torque, 33 g fuel tank, air suspension (have this on my Grand Cherokee and love it), Night Edition, fully loaded = around $72,000
2. 1500 Limited, 6'4" box, V8 E-torque, 33 g fuel tank, air suspension, Night Edition = around $77,000
3. 2500 Power Wagon, Level 3, fully loaded = around $76,600
4. 2500 Laramie, Level B, RamBox, Air Suspension, Fully Loaded, Night Edition = Around $77,700
I don't need a diesel, not towing heavy, but do want a 6'4" box for hauling (will not be above payload of PW) . Side hustle is handyman type services where pickup bed is needed. I will be in the mountains of WV where there are steep hills and heavy snowfall. There is a chance of wanting to eventually plow snow with the truck (It's my understanding a PW is not recommended to plow due to front weight) though.
Not taking the plow scenario into consideration, why would I not upgrade to a 2500 if pricing is similar? I know fuel mileage will take a big hit but am I missing anything else that would cause someone to choose a 1500 over a 2500 with similar pricing? There are a few things the 2500 does not have vs a 1500. For example, Limited has more leather, LED headlights, better ride quality.
Thanks
Large lug MT tires may look cool and perform great on rocks and in sand/dirt but are next to useless in anything but super deep snow. Tires tires tires
So what was the msrp sticker price and then what was the dealer add -ons (paint and interior sealants, etc) price$origionally, and what did you finally get them down to. And was that with or without a trade in.?Strategy I used:
- Use the online tool to option the pickup how you want it.
- Email multiple dealers as to what you are looking to order.
- Explain you are shopping multiple dealers and you want to know their best 'out the door price'...that you do not 'need' a new pickup, but that you want one, and that you are not in a hurry.
- Check with your financial institution (bank, credit union), some offer discounts by purchasing thru them.
- Inform the higher dealers of the best price you were quoted...also let them know if your financial institution will beat their initial offer...give them a chance to counter.
- Once you have the lowest price, contact the next lowest offerer and ask them to make it worth your time to buy from them. I had one dealer say they couldn't get within $6k of that price, while another beat it by an additional $500 since they knew I had to drive an hour to get to them.
- Don't answer initial emails immediately, let them set a while... sometimes a day or more. (Reverse their 'game').
I started with 6 dealers within 150 miles, pared down to 3 players after a month of negotiations..got to a lowest 'out the door price' & ended up telling them to let me know when they would include the $250 bumper step! A month later I get an email...not only do I get the step, they did the whole bed pkg (lights, step & bed liner!) for the same price.
I already had a pickup, so I was more interested in the lowest price than getting a pickup right away. Your interests/ needs may be different.
Good luck in your search!
I got Koons Dealership to drop 10.4k of their advertised price at the end of the month and 5.15% financing at my own bank (Bank of America) and my bank wanted 6.15% off their 2023 (7,200-miles) Cadillac xt6 fully loaded, super-cruise and it was only missing the “night vision” and I flew in from Jax. Florida. 9/29/2023
Thank you, Mike at PhatJag@BellSouth.net or PhatJag@Gmail.com.
