I purchased my 2019 Ram DRW used, and the front tires were not reading pressure and were throwing a warning message when I purchased it. After searching the MOPAR sites for new OEM sensors I couldn't find any in stock. It seems like there is a supply issue with these for the HD duallys. After hearing that he Moresensors on Amazon were plug and play I ordered a pair.
Moresensor:
MORESENSOR Compact PRO Series 433MHz TPMS Tire Pressure Sensor | Preprogrammed for Select 40+ American Brand Models 68249197AA | Aluminum Valve Stem | KX-S149
I purchased two of these on amazon. There was no option to order the stainless steel valve stems, but indicates that the part number above should work. After breaking the bead the first time I discovered that there were not sensors on the front wheels and only valve stems. These valve stems had no internal thread to receive a sensor so I also order two Standard valve stems, part no. TPM2025VK, from Partsgeek.com and attached the Moresensor to the valve stems. The screws that came with the Standard valve stems worked with the Moresensor. I did have to apply a little pressure to get the Standard stem to fit the opening of the Moresensor, but it all worked out. I have access to a tire mounting and balancing machine, installed them today and the truck picked up the new sensors and started reading pressure after 2 miles of driving. No programming or other special tools required. Happy to have these working.
Standard valve stems:
https://www.partsgeek.com/ss/?i=1&ssq=TPM2025VK&x=0&y=0
MORESENSOR:
https://www.amazon.com/gp/product/B07VJ272PC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
