20Limited3500
- Joined
- May 3, 2020
When I had my '16 3500 Limited SRW, I had gathered the parts that came inside the tailgate and made a backup cam to be used when we had our camper on the truck. Sucks not being able to see behind you.
Well, with my new '20 3500 Limited DRW, the camera setup from the '16 will not work on the new truck. So I sourced parts from Ram and from an online vendor that sells a housing and cable that would allow me to retain the backup cam for the surround view when our camper is on the truck. I don't have it installed on the camper yet. Just got all the parts and tested it out. Works like a charm. Next time camper is on, I'll be routing the cable and mounting the camera and housing on the back of the camper.
I know there were options for when you ordered a new truck to get some kind of camera setup to work with a trailer. Since I didn't order my truck, I didn't want to go through all the sourcing for that setup. I have $350 into this setup and it'll work perfect for my needs. Can't wait to try it out with the camper on. I'll post more pics when that happens and I've got everything routed and attached. Here are a few pics of the views from just sitting on the tailgate and what it looks like plugged in. The 2 part numbers are the camera itself and the plastic filler plate that normally comes with our trucks to use when you remove your tailgate. I'll post up the location and part number for the housing and cable later.
