Thisisthe-wagon
- Joined
- Mar 24, 2022
Ya looks like I will have to go that route. Seems like the only option at the moment.
So it does throw codes. I thought that was the case. Any issues with codes being thrown for TPMS lowering? Also I have the link MX and not the MX + Any reason it won't work on this new truck?
Looks like I am about to go the same route.Well guess I'm getting a tablet then seeing our old kindle fire is getting rediculously slow. Hopefully when I setup the new one I can get the newest verious of alpha obd. I cannot get the other one to update to save my life.
Did you download to a galaxy phone or tablet. Was going to look at getting it just wasn't sure if I should get a separate device.Tire size went fine. I got it so I'm actually going slower by .75 to 1 mph under now which is fine because my Toyo R/T's I'll be running in the winter are slightly bigger. All those fault codes getting thrown is a bit scary though. I was in the middle of doing it when my fire pager went off yesterday so I rushed through it. Worked out ok though. Alpha OBD is the best option right now if you can get bypass harness.
Appreciate the info. Is there a bypass cable you recommend or best place to pick one up.It doesn’t matter what it’s on as long as it’s android. I actually had it on a Kindle last time and it worked but I couldn’t transfer it over to the new galaxy. I couldn’t get it to update on the Kindle so I had to re-purchase it
Yeah the speedometer calibration is a bit scary. Glad I'm done doing it and anything else for the time being.Well, nevermind I guess. I went into the engine module instead of the body control module to try to read and clear codes. Problem is, AlphaOBD doesn't have a proper ISO connection to this module on a 2022 (apparently). The app gives you the option to continue even though it may not read correctly. I took this leap of faith, and successfully cleared the CEL.
I have to say, I've worked on my 2009 JK, and my wife's 2020 JLU with tuners/programmers. AlphaOBD has to be the single LEAST intuitive piece of software I've ever seen. Or maybe it's Chrysler's fault...I don't know. Either way, this was bananas.
Not any more lol. Price went up tooJust FYI, AEV has ProCal snaps back in stock. I ordered one and just used it on my 2022 level 3 power wagon and it worked perfectly. Just be aware that when your plugging in the pig tail wire it goes into the blue connectors up and to the left (looking from underneath)
Call themNot any more lol. Price went up too
How long ago did you buy this? Off the website?Just FYI, AEV has ProCal snaps back in stock. I ordered one and just used it on my 2022 level 3 power wagon and it worked perfectly. Just be aware that when your plugging in the pig tail wire it goes into the blue connectors up and to the left (looking from underneath)
