Speedo Recal?
NomadPNW
Sep 13, 2020
So I just picked up the new tires and they are 295/70r18 which comes out to 34.30 for the Nitto Ridge Grapplers. So on the truck and chalk tested they are from the top of the tire to the ground a hair over 33s. I have the AEV ProCal so I can adjusted the speedo. Should I even bother since top of the tire is 33 which is same size as factory. Or the sidewall side since with no weight it’s most likely 34 haha 46B12888-81ED-47EB-8C4D-E55786DE7760.jpeg
jadmt
Aug 29, 2020
Age
65
Missoula
Pro cal uses actual height so no need but you can easily check your speed to make sure using a gps or phone speedo app.
NomadPNW
Sep 13, 2020
So if they measure out to the same size with weight on them there is no need to recalibrate? Also the ProCal is not left in the vehicle you plug it in adjust and unplug. Least the one for the 19s works this way.
MikeXM
Nov 30, 2019
I wouldn't just trust the tire height to be "similar". Use a GPS speed app on your cell and go at highway speed on a flat straight length. You will see if you need adjustment or not.
jadmt
Aug 29, 2020
Age
65
Missoula
Yup that is what i would do.
MikeXM
Nov 30, 2019
So I just picked up the new tires and they are 295/70r18 which comes out to 34.30 for the Nitto Ridge Grapplers. So on the truck and chalk tested they are from the top of the tire to the ground a hair over 33s. I have the AEV ProCal so I can adjusted the speedo. Should I even bother since top of the tire is 33 which is same size as factory. Or the sidewall side since with no weight it’s most likely 34 haha View attachment 7952
BTW the 33in oem size tires probably sit at 31.5 on the truck. So yah, those RG will give you a different (faster) speed than indicated.
Save a ticket, calibrate your truck.
Distillusion
Jul 23, 2019
If you don't calibrate to the new tire size, no big deal, but your odometer will also read about 10-12% lower mileage traveled than actual. And in turn, your comp will determine about the same loss in mpg. Just fyi.
Plum Cra Zy
Feb 21, 2020
So the MPG comp might be pretty close! That's about how much mine is off.
AEV_CUMMINS
Dec 3, 2020
Vancouver, B.C - Canada
Hmmmmmmmm so you say run 42'' and don't recalibrate and justify to wife by having higher re-sale value... genius! =p
