from AEV.
Will the ESP in my vehicle system be affected?
Yes, for the better. The ESP system uses vehicle speed along with individual sensors that measure acceleration both front-to-rear and side-to-side. ESP functions by calculating how much steering angle the user inputs and how fast the vehicle is going, and then calculates how much side-to-side acceleration should occur. If the side-to-side acceleration is less than what the ESP predicts, that means the vehicle is sliding and it will try to correct the situation by applying specific brakes at each wheel and/or reducing throttle.
If the tire size and gear ratio values are incorrect, the calculations the ESP system processes will also be incorrect. This can cause the ESP system to trigger at the wrong time, which at best can be annoying and if it happens at the wrong time (or doesn’t happen when it should) can be dangerous. Lifted vehicles are more prone to inadvertent ESP activation, because the speedometer is wrong. The ProCal SNAP will allow you to fix this issue so your ESP can function properly.
