spare tire size
Dman13
Nov 25, 2023
I'm new to site, question may have been answered many times. I bought a 2020 Ram Limited Off Road new in 2020. It came with 20x8 aluminum wheels and appropriate tires. I just now laid under the back of the truck and realized that it only came with an 18" full size spare. Is that normal Ram procedure?
Yes, all HD SRW trucks get a 275/70R18 Trashforce HT spare.
Gondul
Prince of Pintops
Mar 10, 2019
Done to reduce cost likely.
Essentially the same size.
I run a set of 275/70R18’s for hunting and then the 286/60R20’s the rest of the year. Last year when I put the 275’s on I noted the OEM circumference and then adjusted the speedo for the the 275’s. When I put the 285’s back on I went back to the OEM setting and realized the speedo was off, by the time I got it adjusted with a gps and the odo reading (more accurate than speedo reading) the 285’s and 275’s use the exact same setting.
They have both worn enough tread down than I need to make another small adjustment. The 275’s will probably come off today until next September.
