01Time
Has anyone else swapped out halogen headlights for OEM LEDs and the turn signals won't work?
Here is what I did in AlfaOBD:
And here are the error messages:
Code:
Car configuration change: LED Front Turn Lamps Present: ' NO ' -> ' YES '
Car configuration change: LED High Beam Lamps Present: ' NO ' -> ' YES '
Car configuration change: Front Park/Signature Lamp Left - Pin A-7: ' NO ' -> ' YES '
Car configuration change: Front Park/Signature Lamp Right - Pin A5: ' NO ' -> ' YES '
Car configuration change: Signature Light Present: ' NO ' -> ' YES '
Edit (these were also changed, but were inadvertently left of the initial post/list):
Car configuration change: LED low beam lamps present- YES
Car configuration change: LED front park/marker lamps present- YES
Code:
Error code: B2204
ECU Configuration Mismatch
Incorrect component installed
Last test completed positively
Error intermittent
Failure warning lamp 'ON': Not requested
Error code: B1756
Front Right Turn Lamp 2 Control
Short circuit to + battery/Open circuit
Last test failed
Error present
Error code: B1757
Front Left Turn Lamp 2 Control
Last test failed
Error present
Error code: U0232
Lost Communication with Blind Spot Detection Module
(This is an ongoing issue...waiting for a new module under warranty.)
Last test completed unsuccessfully
Error present
