Sliding Rear Window Noise
goodoldcbcjohn
Mar 18, 2021
When opening the rear sliding window I get a grinding noise and when closing the window it moves extremely slow like it doesn’t want to close. Anyone else had this problem and if so what did they end up doing to correct it?
Will_T
Jan 23, 2021
Southwest Oregon
On my old truck with manual window this happened a few times. Gritty grinding noise and harder to close. I just had to clean the track so that might be a first place to check.
Rooster Bob
Jan 5, 2021
I'm having the exact same problem to the point where if I open the rear glass all the way the motor can't reclose it without my help... - Did you ever solve this?
GRam2500
Mar 8, 2021
Mine would open 1/2 way fine and then barely moved to all the way open while making noise. They just replaced the whole rear window under warranty.
goodoldcbcjohn
Mar 18, 2021
Mine ended up getting fixed by the dealer. They said there is a piece of trim behind the seat that came loose and was causing the issue.
