I doubt there's a tonneau cover out there that's truly 100% leak free ......I don’t know anything about the options you are asking about but the Bakflip MX4 has a stellar reputation. I had one on my Rambox truck and liked it a lot except for (because of the Ramboxes) I couldn’t get it to stop leaking. I ended up removing it.
Since you don’t have that problem I’d seriously take a look.
I've always used BakFlip .... great product.Ordered my truck without a tonneau but actually need one. I am between ordering a WeatherTech Alloy cover for $1100 or a Mopar cover which I believe is just soft vinyl for $600. Any preferences?
The weathertech is a lowmaxJust installed a Lomax Folding Hard Cover. Outer surface seems quite a bit more durable then the MX4 that I had on my 1500. There are a ton of options for bedcovers out there, to fit every need/size/budget/etc, the toughest part is picking the right one. Also look at the UnderCover Armor Flex. Same parent company as Bakflip, but again, more durable surface.
Get a Diamondback, holds 1600 lbs. for those times when you need it. I put one on my truck thinking I wouldn't need the weight capacity, used it several times for loads close to 1000 lbs. with no issue.Ordered my truck without a tonneau but actually need one. I am between ordering a WeatherTech Alloy cover for $1100 or a Mopar cover which I believe is just soft vinyl for $600. Any preferences?
