So i just installed the BBK 90mm throttle body to pair with my throttle body spacer and my S&B Cold Air Intake System. everywhere says its a plug and play no issue run but i ran into a problem. if i let on the Gas pedal hard it will pull to around 4k RPM then shift then i get a Flash on my dash Service Electronic Throttle Control then it blips away. but when that pops up i get a flash of loss of power. Checked for vaccum leaks and everything there isnt a single issue there. Any thoughts?
