When my sons 2019 did that he had to unhook the batteries for ten minutes and reconnect them , after that everything reset .Anything I can try at home?
I got the message yesterday driving, it went away but comes on when I start my 2020 with 3000 km...
The gauge was showing 1/2 full, I filled it up and the gauge didn’t move
Sounds like you have a lot more serious problem than my son did , only difference was he actually touched the positive and negative cables together after unhooking both batteries and isolating them by laying a towel over the batteries so no cables could touch the batteries. He said doing that totally powers down the computers and restarts them when hooked back up. Probably won't work for you but it fixed his. By the way he was already in limp mode when he did that and couldn't stay on the freeway going 5 mph any longer . Sounds like it's time to make a trip to your dealer.I disconnected the batteries all night with the truck in a heated shop and still got the message this am.
I now have a countdown to limp mode on the screen...
I just had the issue with a little over 1,200 miles on truck on my first road trip. Went to the closest dealer on the route and they told me the DEF pump/module in the tank wasn't sensing there was any fluid and they didn't have the part to replace it till the following week. It was pretty much going to strand us in the middle of Georgia over the weekend. The guage on the dash was a little over 1/4 so I filled it up and went for a drive and it went away after about 40 miles. I just made sure it was over 1/2 for the rest of the trip and now that I'm home, my local dealer is going to look into it and replace the module.
Thank you, will do.You should probably ask them to apply the latest ECU update before they rip your truck apart. I just went and pulled the info off my receipt.
The TSBs were:
18-010-21
18-18-04-ME
Did he have any message saying it would go in to limp mode or just the service def system message? I got some driving to do this weekend i dont need it going in to limp mode on me lolSounds like you have a lot more serious problem than my son did , only difference was he actually touched the positive and negative cables together after unhooking both batteries and isolating them by laying a towel over the batteries so no cables could touch the batteries. He said doing that totally powers down the computers and restarts them when hooked back up. Probably won't work for you but it fixed his. By the way he was already in limp mode when he did that and couldn't stay on the freeway going 5 mph any longer . Sounds like it's time to make a trip to your dealer.
I just got this wonderful message on my way home im gonna try pulling the battery cables and discharging the capacitors( touching the pos and neg together) we shall see i know about a weekago i got a CEL for DEF module unable to communicate but i cleared them and it didnt reappear
The issue when it said comunication issue makes me think the module is screwed or needs a reset i have 15k miles on the truck in less than a year but i will see the dealer anyway as i need a couple tsbs one for the hvac box and the ecm reflash for engine performance as my idle is a little sporadic in the cold.I haven't put a ton of miles on my truck since the flash, but it hasn't come back since. I can't find any details on what the TSB changed, but given how many trucks had this happen at the same time, I have a feeling it's bad code that is triggering based on the number of hours the ECU has been powered on since manufacture date. If I'm right, you're just wasting your time with the battery stuff, it'll just keep coming right back until you get the flash.
I got the countdown to limp mode after about 40km with the def message and cel on. My countdown was 180km or soDid he have any message saying it would go in to limp mode or just the service def system message? I got some driving to do this weekend i dont need it going in to limp mode on me lol
Good to knowI got the countdown to limp mode after about 40km with the def message and cel on. My countdown was 180km or so
He said it said def low warning 50 miles or something like that and so he went to fill it up and it went into limp mode before he got there. After that he was on the freeway and couldn't go 5 mph any longer so finally stopped and unhooked the batteries touched the cables together and then rehooked everything back up and everything was fine.Did he have any message saying it would go in to limp mode or just the service def system message? I got some driving to do this weekend i dont need it going in to limp mode on me lol
Thx for the info my message disappeared and the CEL came back on for def module codes i cleared em again and its not on now but i have a dealer appointment on wed i hope its just a flash lolHe said it said def low warning 50 miles or something like that and so he went to fill it up and it went into limp mode before he got there. After that he was on the freeway and couldn't go 5 mph any longer so finally stopped and unhooked the batteries touched the cables together and then rehooked everything back up and everything was fine.
