Rubbing / Grinding sensation in the driveline....
Snagster123
Apr 28, 2023
2020 PW: so after about 7 trips to 2 different dealers, STAR cases, etc.., they still can't diagnose. Rubbing / Grinding at slow speed like 0 to 4 mph then it goes away. This happens in forward and reverse, but not in neutral. Kinda tells me it's in the trans or maybe in the T-Case. I'm still under full drivetrain warranty, sooooo tired of this and soooo tired of taking it back to them...
Any ideas?
ppine
Mar 11, 2023
Nevada
Change the lubricants in your front and rear diffs.
Check the U joints.
Snagster123
Apr 28, 2023
Check the U joints.
Dealership did all that. I paid for a front end service (fluids), and they changed out the entire carrier assembly in the rear axle. Not the u-joints.
Snagster123
Apr 28, 2023
Brake pad sticking?
Dealer says no. But to be honest, it does sort of feel like a brake pad sticking... this truck has a lot of systems related to the brakes like Hill Decent, Hill Launch, antilock brakes, Adaptive Cruise Control, Collission Avoidance, etc... something in there could be messed up...
Snagster123
Apr 28, 2023
At this point, I am hanging my hat on either the Transmission or the Transfer Case. Pretty sure the Transmission has clutches in it. Does the Transfer Case have clutches or is it Gear or Chain driven?
AMDPSU
Dec 8, 2021
Going straight forward/backwards from a stop or turning?
Both my 19 and 22 Power Wagons had a vibration when turning from a stop.
Same run around from the dealer so I decided to change the rear diff fluid on the 22 to Amsoil at 17k miles.
No more vibration...
2powerwagons
Apr 9, 2021
Did you try turning off the hill start assist (or whatever they call it)?
I know it will make a chattering (for lack of a better term) when starting.
I leave it off, never use it..
On a different truck, dealer replaced the rear locker coil. Truck had a shudder when starting and turning. Kept taking it back. Eventually I talked them into checking the preload on the diff carrier bearings. Turns out they were set a little too tight.
2powerwagons
Apr 9, 2021
One other thing to check, the flex plate. They can develop cracks that propagate out from bolt holes and can make all kinds of strange noises.
It seemed common on GM trucks at one time and I've never really heard of it on Rams.
Snagster123
Apr 28, 2023
hill start.. turned off. They have replaced the entire rear carrier.. no change.
Snagster123
Apr 28, 2023
So these Power Wagons dont have clutches in the differential... they are gear driven positrak units... They have replaced the entire rear diff/carrier along with new fluid. they did add friction modifier which I dont understand adding for a unit without clutches. IDK...
