burtonfamily101
- Joined
- Oct 13, 2021
The spring itself is in the isolater just fine. At least it is pushed up to the flat part with the spring, if that makes sense. I can try and get a pick soon, But I like the idea of dropping it and making sure the spring/isolater is good.OP, that looks like a spring isolator issue to me. I’d recommend dropping the front suspension again and verifying the springs are rotated correctly in the isolater . If they aren’t plan on replacing the isolators.
Do a google search on Ram 2500 isolators and you’ll see this happens frequently, even with the expensive springs.
Far as the alignment goes, I can see the caster but still in the middle. The picutre is of the passanger side, would anyone know what way the airrow needs to go before I start messing with it next weekend? I assume forward to the back of the truck.
Sounds like I need to loose the other two bolts and adjust that one, does that sound right?
