Rhino Rack opinions
TogaLock77
May 5, 2020
I have an ARE cap on my 2500. I want to run a platform rack on the cap and on the cab roof. I'm trying to decide if I should go with the Rhino Rack Backbone on the cab and the standard towers on the cap. Or go with standard towers on cab and cap. The Backbone is not available for the ARE cap. Thoughts? Anyone running a Pioneer platform by Rhino Rack?
LateToTheParty
Didn't want to come
Jul 29, 2020
Roxborough, CO
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
OP I’m glad you posted that pic. I’m waiting on that’s same topper and yours looks great! Should be any day now for mine.
SFAngus
Feb 27, 2021
Marin County, California
I'm interested in what you find out as well... I ordered the RSI Smart Cap with the Drop Rack on top, and I'm considering adding a platform rack to the cab of the truck as well. I'd love to see some different setups that people have been successful with.
This is the drop rack:
TogaLock77
May 5, 2020
That smart cap is nice. I wish I would have know about it when I ordered the ARE. Is it fiberglass or aluminum?
Due to cost, I will be going with the Rhino Rack for the cap first. It might be a while on the cab.
TogaLock77
May 5, 2020
I'm extremely happy with the Rhino Rack Pioneer platform. I've seen a few platforms out there and they stand too high off the roof. The Rhino Rack keeps things nice and low with little space between the roof and the platform. The Backbone mount on the cab was stressful because it does require drilling into the roof and installing rivet nuts. I ended up with the Backbone on the cab and standard towers on the topper. The Backbone is available for the topper, but an order placed in June was tentatively expected in May 2022. I needed the rack so that wasn't an option. I figure I can add them in the future if I'm not happy with the standard towers. 7E2DFBE8-091B-427E-A88A-2016E06F3DFD.jpeg30C8E0A2-40EE-4803-B725-A5974D68B73A.jpeg2A727A66-9A26-407D-B932-098DEA32250D.jpeg3357CEB8-FBD8-4C84-A413-BC4A0080C347.jpeg79A86997-BDEC-4FAF-B5D1-A00531FE322F.jpeg
Metternacht
Jan 15, 2021
I am considering doing this also, I assume access under the rack for cleaning is limited? Do the rubber trim on the roof just go away entirely? and what is the clearance like on the fin antenna? Also any performance degradation with the antenna?
Thanks,
-M
TogaLock77
May 5, 2020
Thanks,
-M
To install the Backbone you have to remove the rubber trim from the roof gutter. It's just there for looks. You could cut the rubber gutter trim and install it between the mounting points of the Backbone if you like. So far as cleaning, I have a telescoping pole with a sponge attachment that will work. The clearance from the shark fin is about 1/2 -1 inch I think.
