Researching new wheels for my 2020 RAM 3500 dually
RV_Goose
Aug 14, 2020
My 2020 RAM 3500 dually came with the steel wheels and the chrome plastic covers. I am consider replacing the stock steel wheels with aftermarket rims. So I am searching for a set of 7 wheels that will handle what my 3500 is rated for as well as looking good.
I do not have any idea what the specs are on my stock wheels. I am not looking for larger tires on my 17 inch rims.
I have found many optionsfor the SRW 3500s, but not so much for DRW.
boatdude1
Nov 16, 2020
I just sold my 2019 3500 DRW. Just something to think about.... once you change your wheels you cannot rotate them. The tires have to be removed from the wheels and rotated. These trucks tear up front tires quickly and need rotation. If I did it over I would not change the wheels. I put Alcoas on mine.
OuachitaAdventure
Jul 3, 2019
I just had mine rotated because of the front tires wearing so much. rears were great; fronts wear fast.
RV_Goose
Aug 14, 2020
Well, I was kinda hoping I could get 6 wheels and that they would rotate the same as my steel wheels.
boatdude1
Nov 16, 2020
That is what I did. The centers on the rears got torn up where they rub together and the center caps do not cover that whole area. Looked like crap in a few thousand miles and I could not rotate them like I hoped. Good luck and I hope you find a good solution.
OuachitaAdventure
Jul 3, 2019
I think Alcoa makes a 19.5 that you can rotate that way, but that may not be a direction you want to go.
RV_Goose
Aug 14, 2020
Okay....scrap that idea. I stick to stock.
Duke Silver
Mar 30, 2021
I was reading the manual for my 21 DRW today, and it said to keep all the tires in the same position, just swap sides. So swap the two fronts, swap the two inside rears, and swap the two outside rears. It said it had with the TPMS.
At that point the rotation is useless and a waste of time
RV_Goose
Aug 14, 2020
Same for my 2020 manual. Yet the dealerhsip said they commonly rotate the duallys.
BAT3500
Nov 29, 2020
I am guessing dually's with the nice black rims are truely screwed in regards to tire rotation without swapping tires on the rims.
boatdude1
Nov 16, 2020
From my dually experience. Yes, no way to do it without taking the tires off the wheels.
