Squatch
I put the infinity primus 6x9s in. They come with a spacer that works perfect to get enough space in the front door. I did front and back on the driver side and left the passenger side untouched so that I could fade from full left to full right. It sounds like a did lose some lower thump, but definitely gained a lot in the clarity of sound, but after listening to them for a couple of hours on the road with some different genres of music, the treble was just too much. I found myself turning the treble down as far as it would go, cranking the bass as high as it would go, and trying to coax some mid out of them and it just would not even out, it literally hurt my ears to listen to it, I ended up shutting the radio off and listening to wind the last hour. I put stock speakers back in the next morning and I was very happy to have those oems back in there. Good news is the job only takes about an hour and a half, each door skin comes off in under 10 minutes. I would not recommend this swap for the base 6 speaker system with the 5” screen.
