Savin yours
- Joined
- Dec 5, 2019
2019 DRW 3500 Longhorn. 2 1/2”?
Correct. It's a class 5 hitch receiver.2019 DRW 3500 Longhorn. 2 1/2”?
To add to this, you do get a 2" receiver adapter included with your truck. Mine was under my back seat.Correct. It's a class 5 hitch receiver.
LolI just found my adapter last weekend in the rear floor storage compartment. Only took me 5 months to figure out it was in there.. Hopefully the right turn clunk goes away now. Yeah right!
I was standing in the tow accessory section of Crappy Tire looking at hitch adapters the day I bought the truck. "I'll pick one up later," I thought to meself. It was the following day when I found the nest egg under the back seat. Dealer didn't have a clue.I just found my adapter last weekend in the rear floor storage compartment. Only took me 5 months to figure out it was in there.. Hopefully the right turn clunk goes away now. Yeah right!
Kills me the factory doesn't supply a hitch receiver pin with the adapter.I was standing in the tow accessory section of Crappy Tire looking at hitch adapters the day I bought the truck. "I'll pick one up later," I thought to meself. It was the following day when I found the nest egg under the back seat. Dealer didn't have a clue.
I think all the 3500 owners have to buy drop hitches to tow regular stuff. I'll purchase mine soon, thinking of a 6" with 3 different ball sizes to cover most trailer-type situations.I didn't know there was a supplied adapter either. I had to purchase an 8" drop hitch as this new trucks receiver is 8" higher than my F150 4x4. So the adapter wouldn't have worked very well anyway. Boat would have been angled up like getting on plane, but on the trailer, LOL.
Sent from my ONEPLUS A6013 using Tapatalk
Good point.I had to get a 7-3/4 inch drop for my camper. My friend wanted me to haul a jeep for him on his trailer. Had to get a 10 inch drop.
I would have to suggest...an adjustable hitch of atleast a 10 inch drop.
I have a 2020 3500 CC LWB DRW 4x4. I went with a Weight Safe SWS6-2.5, 6 inch drop for a 2.5 inch receiver. My old one that I took off my 2006 Ram was perfect, so I stayed with a 6 inch drop. I didn't want a longer one as I don't want it to drag on things in case I go off road or something. My Trailer sits 1.5 inches higher in the front than the rear when empty, once the trailer gets loaded, it is level. Keep in mind, each truck and trailer hitch varies some you you need to make sure what you need before you buy and don't purchase something that won't work. I also hate the Boat Anchor Look. If you check out the photos below, I have pictured a 10% promo code they sent me in the box with my purchase. Also if you ask their receptionist if there are running any promos/discounts, she will be able to help you out. I got 2 additional locks, a $50 savings.
Here are some pictures of mine:
UPDATE 4-30-20 :
I have called and started the return process. There is to much slop and banging when pulling and stopping the trailer with this hitch as it's fitment is to small for our 2.5 receivers. The lady on the phone told me where to get tape (at my expense and you have to regularly replace it) and wrap around unit to fill in the gap difference. I guess they know of the problem but have no plans to fix it.. Poor Customer Service I say. They have a Good Idea but is to sloppy of a fit.
Towed a 8500 lb bumper pull fer 4K miles last summer with the sleeve and... nuthin of note. Did what it was apparently deigned to do. I suspect it'd be fine up to the max limits for 2-inch, class V hitch accessories.Class V 2.5" I didn't trust using the factory sleeve for even one tow. This Andersen hitch will last forever. 6" drop. Perfect to fit to the boat.
Updated above post. Returning item
Amazon.com: 2 1/2” Class V Hitch Tightener GH-063, Fits 2.5" X 2.5" Hitch Receiver Anti Rattle, Anti Wobble: Automotive
Buy 2 1/2” Class V Hitch Tightener GH-063, Fits 2.5" X 2.5" Hitch Receiver Anti Rattle, Anti Wobble: Hitch Locks - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I think you are going to find the same amount of slop unless you find a lathe and make your own. Even Gen-Y understands understands this and makes a hitch tightener.
@1FastHemi
x2 on the customer service at Weight Safe. Luckily i declined the delivery before it got here.
Im about to pull the trigger on Trimax Heavy Duty TRZ8ALHD 8". The HD model is 2.5"
It looks better than the Weight Safe and has 20k payload (over 18k on weigh safe).
I saw a review from a ford guy who bitched about having to file down the corners to fit into the receiver. I hope min is that tight.
