Burton12387
Had this new campaign recall pop up for my truck, but can't find any additional information on it yet.
VB6 - 2019 DJ D2 Diesel Engine Calibration.
Called dealer and they said it is a software update and they do not have parts for the trans recall yet
If my truck is involved, I will hold out on this until enough people have it done, and can say whether performance is hampered, or not.
So an HO Cummins with Aisin is not included in this?Hello all. VB6 is part of the recall for the Transmission Valve Body and will be performed at the same time. We do recommend scheduling an appointment as soon as possible to address this. If anyone needs assistance, please send a private message!
Kate
RamCares
Just left my dealer and was told no parts available. Now I’m scared to death to pull my trailer with my Harley’s in it for fear it’s gonna catch on fire! So much for my winter trip to Fla! Thought when I bought this one my troubles were over, guess they are just starting again!.........:-(((Hello all. VB6 is part of the recall for the Transmission Valve Body and will be performed at the same time. We do recommend scheduling an appointment as soon as possible to address this. If anyone needs assistance, please send a private message!
Kate
RamCares
I’ve towed 8k for hours on end, and climbed a ski resort maintenance road to 4000’ trans temps around 210 degrees and did not exhibit and trans fluid puking out. I’d make sure the dipstick is pushed in and enjoy your trip. Oh, and carry a fire extinguisher just in case!Just left my dealer and was told no parts available. Now I’m scared to death to pull my trailer with my Harley’s in it for fear it’s gonna catch on fire! So much for my winter trip to Fla! Thought when I bought this one my troubles were over, guess they are just starting again!.........:-(((
Thanks for the info!!!!! Much appreciated!!!!! That does make me feel a bit better hearing that. I sure don’t need this thing going down in flames on I-75 with 2 bikes in the trailer........:-/ Great idea on the fire extinguisherI’ve towed 8k for hours on end, and climbed a ski resort maintenance road to 4000’ trans temps around 210 degrees and did not exhibit and trans fluid puking out. I’d make sure the dipstick is pushed in and enjoy your trip. Oh, and carry a fire extinguisher just in case!
What will they address???Correct it is NOT apart of this recall however there is an ECM and TCM flashing coming by the end of the 1st quarter.
Thank goodness!!! I hope they finally get this HO/Aisin combo working as it should. Hopefully, somone will post up when they are released. Thank you, Nordic Nevs!Hard shift and driveline complaints Along with high elevation operations.
Thank you so much for this info!!!! I will do just that!!!!!Hey, Curt. At this time, you are still able to drive your vehicle until your recall is repaired. While driving, we recommend frequently monitoring the transmission temperature while in operation using the gauges available on the instrument cluster. If transmission temperature exceeds 210°F, immediately proceed to a safe location to park the vehicle and allow the transmission temperature to cool to less than 190°F. We hope this helps.
Kate
RamCares
Different than this?Correct it is NOT apart of this recall however there is an ECM and TCM flashing coming by the end of the 1st quarter.
2019 Aisin shifting is weird and poor - why?
I'd agree about the newer version of the transmission. I had a 16 DRW with the Aisin which shifted much more smoothly than the one in my 19 SRW. I will also check with the dealer about the programming. My truck was built in March of last year, I believe, so I'm not sure which update it would...hdrams.com
