Rear Lockers
bht222u
Sep 9, 2020
I've ordered a 2021 2500 Laramie 4x4 w/Cummins.
I want to add a rear axle locker, what are some personal experiences with which type and brand of locker for an diesel HD.
Lary0071
Dec 9, 2019
Pittsburgh Pa (Beaver County)
I would go with a Eaton TruTrac instead of a locker. A TT is an amazing mechanical limited slip device that works extremely well. The only time it will fail you is if a tire on the axle is in the air, but your not rock crawling on Jeep trails, so that would not be a limitation. I run an Eaton E-Locker in the front and a Eaton TruTrac in the rea. It is unstoppable.
bht222u
Sep 9, 2020
I had an occurrence in my 1500 4x4 with limited slip where both left tires were in a muddy ditch and the other side on a road and couldn't get enough traction to get out on my own.
I want to know both rears were turning should I find myself in a similar situation again.
renagade69
Nov 10, 2020
Learn to use the system below. It's built into the ram and in the Traction Control part of the manual.
  • Brake-lock differential system (BLDS): Allows the vehicle to maintain forward motion if one or two wheels lose traction by selectively and aggressively applying brakes to the spinning wheels
regal2800
Apr 23, 2019
where is that in the manual? i couldn't find anything on that feature.
It works ok but not as well as they make it sound, my 2014 jeep had it and it was not that good
With the factory anti spin axle it works well
Subduedracer
Dec 23, 2020
Hi Larry - Where did you buy your Eaton TruTrac for the rear? I called Nitro Gears and they told me that my rear isn't an 11.5 AAM. They said they pulled in a 2020 Ram 2500 and the rear LSD they have wouldn't fit.
Lary0071
Dec 9, 2019
I run the TT in my 2014 Wrangler with Dynatrac ProRock axles and in my 2003 Cobra SVT. My truck doesn't have or need one since it's on paved roads only, but it does have a sadly lame factory limited slip.
Call Mark Petros at Greensburg Machine and Driveline and see if he knows more. In the north eastern USA, Mark is the guy that builds axles for drag racers, sled pullers, and off roaders who come in from states around. He would be who I called if I wanted to find something. I know that the factory one is junk compared to an aftermarket. Heck, I would go Auburn or some other aftermarket clutch style that actually worked if I had to.
Bobby Boca
May 1, 2021
I just bought a 2021 Laramie 4x4 Cummins midnight the truck was on the lot had basically everything I wanted but not anti slip diff I want to add it also did you install yours after market yet? From what I’m hearing is that there isn’t any after market lockers for 2021 2500 on the market yet .. let me know how you made of .
Gswain
Apr 1, 2021
good luck finding diff parts for 19+ diffs.
let us know when you do.
Isnt that only true of the 3500? I was under the impression that the 2500 still retains the aam 11.8 which is compatible with the 11.5 carriers, like ARB.
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Nope no gears or anything fit. Will be a few years from what nitro people are saying.
el_barto
May 25, 2020
Yukon gear told me the 2019+ 11.5 Rear diff internals changed substantially (different pinion diameter, different carrier, different axle shaft diameter) so lockers and regear kits won’t fit
