Yes, the numbers are from the door sticker 5500lb front and 6390lb rearmine says 6200lbs on the door sticker. is that where you are getting your number from?
I have a Laramie Crew cab 4X4 6'4" box, the closest one I see on the chart is the Tradesman 4X4 Crew 6'4" and it says 6000lb. I am just curious as to what makes the difference?Could be you have one of the trucks on the attached that show 6390 for rear. (yes its 2021 but should be same for 2022)
Very good question. You’ve made me curious. I also have a 2022 Laramie 4x4 with 6.4 box, but it's diesel. Sticker for rear GAWR is 6,040.I have a Laramie Crew cab 4X4 6'4" box, the closest one I see on the chart is the Tradesman 4X4 Crew 6'4" and it says 6000lb. I am just curious as to what makes the difference?
what does the other sticker say the pay load is?Yes, the numbers are from the door sticker 5500lb front and 6390lb rear
Hi Ram brotherZ,
I have a 2022 Ram 3500 DRW.
Anyone knows What is the front & rear GAWR please?
I know it’s not 6k (front) & 9,750 ( rear) according to door jam decal.
Can’t find nothing on the AAM manufacturer website.
Thx in advance!!
Axles are rated for more than that, its rated @ 6k on front &That’s exactly what it is.
The axles may be capable of more (rear is, front I’m not sure), but the GAWR’s are what the suspension, frame, axle are rated for as an assembled unit.
THX FOR THE QUICK RESPONSE!!That’s exactly what it is.
well, a lot of owner operator are saying the opposite since axles are rated for more than that.
Axles are rated at 6k (front) & 9,750lb (rear) because of the original piece of **** (tires & wheels 17’) that A new Ram comes with.
But if you have 19.5’wheel rated @ 5,000 lbs each and 19.5’ commercial grade rated @3,750 lbs each, is different game.
AAM have a disgusting website & can’t find my answer.
I’ve seen a bunch of people re rating the axles as they run 19.5’ wheels and tires.It’s not a tire and wheel restriction.
A SRW truck has enough tire and wheel for at least a 7K rating , but the front is still only 6K. It’s the same axle/frame/suspension SRW vs DRW. The DRW adapters may reduce wheel bearing and ball joint life, but the axle can hold the same in either application.
A DRW has enough tire and wheel for a 11,340 rating, but it’s still rated at 9,750.
The original AAM 11.5” axle was rated at 10,912 lbs by AAM. I sure the new 12.0” housing is stronger, but I don’t know the specs.
Either way it’s immaterial, as the truck itself isn’t rated for more. The door sticker axle ratings are what you get on a DRW.
Anyway you could find the AAM specs on the front & rear? I will greatly appreciate it
So frame & suspension has to be upgraded as well is that what you are saying?Call AAM and ask. That’s what I did 15 years ago.
You can legally change your rating, but it takes a modification. Just putting 19.5’s on the truck isn’t enough on a DRW, since it’s pretty obvious the wheels and tires are not the limiting factor. The frame/suspension are why those ratings are there.
I changed my 05 3500 SRW to have a RAWR of 9K and a GVWR of 12K. That was based on suspension improvements, 19.5’s, and knowing that the same frame had an OEM GVWR rating of 12K and a max RAWR of 9,350 so I was within the max OEM specs but well above SRW ratings.
I wouldn’t upgrade the FAWR/RAWR on a DRW pickup, based on knowing what the truck as a whole is built for. If you need more then a it’s C&C time.
There are several 3500 frames that have bent/broken from overloading with big campers. The axles likely weren’t bothered, or overloaded but the rest of the truck was.
He’s saying you’re SOL. Time to get a bigger truck.So frame & suspension has to be upgraded as well is that what you are saying?
