FWIW my '19 Power Wagon still has the same 11.5" rear axle as previous years. I changed the diff fluid and the gasket part number is the same (40005967) as previous years. It sounds like all other 2500s got the updated rear end. I have also heard they might be coming with a 34 spline pinion.AFAIK, all the 2019+ models use a new 14 bolt diff with different gear sets.
I don't know what ring gear sets are in each, I believe 11.8 for all non HO.
The AAM still uses the Eaton (TracRite GT) anti-spin diff except of course, the Power Wagon with TracRite GTL locking diffs.
The 3500 SRW and DRW HO both have the 12" AAM which has a larger axle tube.
TracRite Differential Portfolio | American Axle & Manufacturing | Aftermarket OE Parts
AAM Aftermarket brand products provides an array of Locking or Limited Slip Differentials for those applications where traction enhancement is a must. The TracRite® Series of limited slip awww.demandaam.com
AAM 12 Inch Ring Gear, 14 Bolt Rear Differential Cover, 2019 and newer
PML extra capacity rear end cover for 12 inch ring gear American Axle 14 bolt rear differentials, 2019, 2020.yourcovers.com
I asked the question because I’m thinking of putting a ProCharger in the new 2500 6.4 for some extra HP & TQ. I will keep it to set to use pump gas. I’m thinking only 5.5 lbs of boost.
I don’t want to blow up the rear end or transmission if I do this.
