Ram 3500 5th wheel prep kit installation.
allthatflash
Jan 16, 2024
So I purchased a 3500 without the 5th wheel prep installed by the factory and none of the 3500 had it on the lot. The sales rep swore that dodge can do the install, but now I'm finding out that the dealer here in Socal won't touch it....I need the 5th wheel prep kit and 7pin harness installed so I can buy my 5th wheel trailer that I picked out... what are my options? I really just want to return the damn truck for the deception.
Many folks have installed it after purchasing a truck. Ram sells the kit.
Try a different dealer.
Unless you plan to tow a GN I wouldn’t bother with installing that.
Part number 82215837AC should be what you need.
allthatflash
Jan 16, 2024
I'm getting a 5th wheel travel trailer, I mean the kit includes the 4 anchor blocks but I also have the GN center piece incase I decide to get into hotshot or something where a GN trailer would be useful.
allthatflash
Jan 16, 2024
I thought it had more to do with it voiding the body (rust/corrosion) warranty .
They say they need a technician in order to cut the bed to make the holes to access the pucks... which so far no dealers had anyone worthy of using hole cutters.
Measure 2 times drill once. The hole locations are pretty easy as the bed flatspots are center of the holes in my truck,
allthatflash
Jan 16, 2024
Ya for sure, I think this will bee my only option since Ram sells 3500 without 5th wheel prep kits installed. Which should be included on all builds. Sad you pay 80k for these machines and we can get **** installed on them that's a dealer accessory that you can buy.
I would go to a bodyshop before a dealer repair shop. Im sure most “techs” these days dont even have a measuring tape
allthatflash
Jan 16, 2024
Ya I've called all the local ones around and nothing.... its pathetic. And the sales person swore they can install it at a later date.... screwing the customers is priority.
Chrisminx
Nov 12, 2020
Do you have to have OEM style? Look at B&W and their companion hitch. You can get the 7 pin harness from etrailer.com and install it yourself.
Grateful Dad
Aug 21, 2021
Georgia
Not a bad job, on my ‘21 I installed the factory 5th wheel prep (4pucks) and went with the B&W for the goose. The template provided by Mopar and B&W make it a breeze. Drilling the bed is easy……..
Gonna do the same on my ‘24, B&W arrived over the weekend!
The GN companion hitch is good, but doesn’t hold a candle to the OEM puck system.
Best of both worlds. I would install the OEM GN, but you can’t go wrong with the OEM 5th wheel stuff.
allthatflash
Jan 16, 2024
I like the Curt Crosswind, but I'll have to wait to get this installed first. I've already added running boards and the bumper step on the truck
I’ve personally never been a fan of Curt products. The B&W 5th wheel hitch for the OEM puck system is hard to beat.
My Curt A25 has been great for the 6 years I've owned it. Same head design as the 30K Mopar hitch Curt makes for them.
I didn't like the Patriot that would have fit my existing rails, so I bought the Curt in 2018 to upgrade my POS Husky drawbar hitch when we got a new 5th wheel. I later converted the A25 to Puck for the new truck.
I wouldn't want the Q-series, which is what I think the entry level 20K Mopar hitch is.
Anecdotally, my buddy with an RV shop/storage broke his Companion GN mounted hitch all to hell trying to move a 5th wheel he didn't notice had a slider adapter. Not only shredded the head plate, but the upright arms and the base were bent. Pretty much trashed the whole thing. I think there was only one structural piece he didn't bend.
allthatflash
Jan 16, 2024
Ya they seem good, I just like the simplicity of the curt system and you don't get grease all over you when removing it from the bed... lol
That should pricey action there... well I need to get the pucks installed before I can think about buying the 5th wheel system.
Had my B&W puck system in and out countless times. Grease isn't an issue.
