I thought the door sticker included a "standard" driver. After all, it doesn't make much sense to show the payload without a driver. Might as well not include the engine also!
No it doesnt include driver it is posted as available payload. Any Person/Passenger takes away from that number. Like i said it didnt even match with just empty vehicle and full tank of fuel. It should be as built with any options etc..
I'm not sure he's doing it right.
Payload number stamped on a door frame sticker is available payload. All standard equipment and options, including a full tank of fuel is already included in the payload calculation.
Basically payload is GVWR - curb weight, and a curb weight is a vehicle weight as it came from the factory, with a full tank of fuel. No driver.
There was a time when PW payload numbers were dismal - right around the time when they switched from rear leaf springs over to coil springs, but I was under the impression that the payload numbers were brought back up in recent years.
Pretty hard to mess up taking a truck across the scales and weighing it and comparing that against GVWR (GVWR - Weight Slip = remaining available payload)
- 2 engineering degrees and needing to do the above is included in job description to ensure any and all testing is within legal and as designed specs
Again the sticker was not accurate even with full tank of fuel as built (but it was close)
Nope still dismal payload numbers (2019 here, so cant use the argument they bumped it up with the refresh)
GVWR - 8565lbs
Payload Sticker - 1083 lbs
First weigh empty truck, full fuel tank, no passengers - 7560 lbs
Available payload 1005 lbs (again i am not in the vehicle and nobody else is)
***sticker is off by 78 lbs just by filling up fuel tank**
-no occupant included in payload sticker
by my math that 78 lbs indicates sticker-ed with about 1/2 tank of fuel
Second weigh 7880 lbs
*tools, sliders, skid plate, front diff guard, off road lights (again no passengers, full tank of fuel)
Available payload - 685 lbs
Third weigh - 8900 lbs
*tools, sliders, skid plate, front diff guard, off road lights, full tank of fuel, snowmobile in bed of truck, me as driver and dog in backseat (St Bernard)
Available payload - (-335 pounds) overweight
I can pull out my binder and take pictures of the other 2 weigh slips if i need to further prove myself
