They tell you 100k because they know the resistance in plugs will increase and burn up the coil packs before 100k miles and cost you 5x the plug replacement. I personally change plugs at 50k.
Not a coil issue, it's a plug issue. As plugs deteriorate the coil has to work harder to produce the same spark as in higher amperage producing more heat wearing out the circuitry.
I don't believe it's a Ram thing. I've seen it in Ford GM and Chrysler. Mostly with high performance and trucks.
Hemi coils have never been a common problem. Certainly nothing like the coils found in the 5.4 Ford engines and their relatives - horrible things.
IIRC my manual says change the plugs every 100k or so. I may do them early. Haven't decided yet. Looking forward to removing the rear two coils on the drivers side...... Wonderful brake booster location.....
