(Provided that a soot-triggered active regeneration didn’t happen in that 24 hour period)Active, they happen every 24 hours of runtime regardless of soot loading in the DPF. The cleaner the DPF, which it would be from towing, the faster they are.
I thought that number seemed implausibly high as well. The cycles are easy to missThat’s what I gathered, so unlikely you averaged over 70 and more likely it was over 24 hours of run time and you missed the regen.
I’ve seen them as quick as 10-15 minutes while towing.
He’s calculating your average speed based on the 24 hours between regenerations and the 1,700 miles. Which is the correct way to gauge what types of drive cycles the truck sees. Total operational hours count towards the regen timer, this includes idle time and low speed driving. Towing is irrelevant. It’s practically impossible to get a truck up to an average speed of 70mph. Mine sees mostly highway driving and regenerates every 24 hours on the engine which usually is about 900 miles traveled. That makes my average speed around 37-38mph.So are we talking passive or active regen? I have seen active regens when not towing but never any regen of any type while towing. Or is there a difference in terms of the display? I may have missed it but I pay pretty close attention to my instruments. And my average speed towing is probably around 55 or so.
I’m certainly no dummy but you guys have me totally confused. Is there a document somewhere that explains the protocol used to determine regens? All I know is I kept the DPF screen up the entire trip which probably took over 30 hours and included five overnight stops. Trailer weighs 22K pounds. Did not see a regen message.He’s calculating your average speed based on the 24 hours between regenerations and the 1,700 miles. Which is the correct way to gauge what types of drive cycles the truck sees. Total operational hours count towards the regen timer, this includes idle time and low speed driving. Towing is irrelevant. It’s practically impossible to get a truck up to an average speed of 70mph. Mine sees mostly highway driving and regenerates every 24 hours on the engine which usually is about 900 miles traveled. That makes my average speed around 37-38mph.
Spot. On.Active regens are initiated two different ways.
1) Time. Once any active regen completes a 24 hour run time clock starts. That’s engine run time, idle or driving. When you hit 24 hours since the last active regen an active regen will occur, even if the DPF is soot free from towing for the last 1000+ miles. This type of active regen can be very short if you have been towing, and are towing when it occurs.
2) Soot loading. If the DPF is accumulating soot the EVIC DPF gauge will indicate the DPF is filling up. At approx 45% full on the DPF gauge the truck will initiate an active regen. This type of regen is typically much longer as there is more soot to burn out.
Both of those will get the same message on the EVIC DPF gauge, “Automatic Exhaust System Regeneration In Progress”
There unfortunately isn’t an official document on this generation of truck.
Since your trip took 30 hours you had a time initiated active regen during the trip and missed the message. It’s unlikely that you had any soot load based regens since you were towing and had adequate passive regen. The time based active regen could have taken as little as 10 minutes if it initiated while you were towing and the exhaust was already hot.
Had it on the DPF gauge the whole time. No regen indication. The speed limit was 70 but I probably drove faster but not by a whole lot. I do have the 4.10 axle so engine speed might be a consideration as well.
