FishermanJer
- Joined
- Jan 20, 2022
My filter on the display is saying it's at 50 percent. What's the best way to get it back to 0%? I have a 2021 ram 2500 diesel Laramie
Thank you, I need to go for a drive then and see.Not sure it is required at 50% but below is what you should do at 80%. Could be possible that nothing happens at 50% when you perform the below steps. Not sure.
OK thank youI wouldn't worry about it until it gets to about 80 . Usually around 50 or so mine will regenerate . If you put a load on your truck it will regenerate really quickly. It should throw a code if there is a malfunction in the system .
I tow all the time in the spring and summer and fall. Winter is the only time I don't tow. So it's probably in need of a good work out.Mine is never detectibly over 0%. I used to wonder if it was even working but others have reported theirs are the same. So trucks vary for some reason I guess. May be driving habits, but my truck is about 70% towing, 30% around town.
There are two triggers that can initiate a regen on these trucks, the first one is a timer in the ecm, about every 25 hours of engine operation it will trigger a regen, no matter what the soot load is.Not entirely sure how Cummins manages their DPF's. I work for Caterpillar and on most of the Tier 4 systems we have, they won't do anything actively with the DPF until it reaches 80% as well. Once it reaches that point, it will actively regenerate the system. You can passively regenerate by loading the engine (pulling a relatively heavy load) for an extended period of time which will increase the heat in the system enough for it to regenerate passively.
Good to know. I deal with "off road" engines so they are handled a little differently. This is my first diesel truck and I wasn't sure how Cummins managed the DPF on them.There are two triggers that can initiate a regen on these trucks, the first one is a timer in the ecm, about every 25 hours of engine operation it will trigger a regen, no matter what the soot load is.
The other trigger is soot load
On a properly running truck that is driven normally and not short tripped or excessively idled the timer will be the normal trigger
Yea my driving habbits consist of the throttle being an ON/OFF switch so thats most likely why the gauge has only moved slightly onceI wouldn't worry about it until it gets to about 80 . Usually around 50 or so mine will regenerate . If you put a load on your truck it will regenerate really quickly. It should throw a code if there is a malfunction in the system .
Same. My truck typically only sees short trips. My gauge has never climbed above zero. It is not driven with a light foot though. Regens only every 24hrs of engine hours so far.Yea my driving habbits consist of the throttle being an ON/OFF switch so thats most likely why the gauge has only moved slightly once
Not sure if he's 100% correct, but he sounds confident LOL.
What I understood is that there are pressure sensors before and after the DPF which are used by the ECU.
Really nice video. Even showed it to my son (11y), he was interested and asked a lot of questions.
If you have 5 minutes, this video from Cat gives a good overview of how an aftertreatment works. This is how most systems work, but may change slightly from Manufacturer to Manufacturer.
When I first started working with Dealers troubleshooting these systems, I spent a day with one of the primary Engineer's responsible for Cat's aftertreatment design.
He sent me the link to this video to help me better understand what was going on.
I don't think my truck has timer for regens. Mine is 2019 and I told the dealers not to flash / update my ECU, and they didn't. I've been hearing about these "timers" and been driving my truck all of the last summer watching the DPF gauge like a hawk. Nope, no 24hrs engine hrs regens.
Some others have reported 24 hrs regens and by that I guess they talk about active regens. I have had the DPF gauge screen on and watched it when it was supposed to roll over 24 engine hrs, and nothing has happened. Did it often enough to confirm it's not happening and my DPF gauge was not always at zero at those times. I only ever see regens when the gauge reads sort of 50-60% full, never had it much higher than that, definitely not 80% full.I think if you were monitoring the DPF EGT's inlet vs outlet and pressure differentials you would see otherwise.
If a flash does anything, it's making the gauge more accurate and truthful.
