Steverin06
- Joined
- Dec 13, 2020
New guy here. I'm planning on ordering an ARB twin and Pacbrake wireless air spring control (https://pacbrake.com/product/hp10325-amp-wireless-air-spring-controls/) for my Timber Grove CRM bags. I will also use the compressor as OBA. My thoughts are the power of the ARB would eliminate the need for a tank for my application (trailer/truck tires, inflatable kayaks, etc).
I called ARB because I've read the fuses for the factory aux switches are too small to power this compressor. ARB said two harnesses come off the compressor - one to the battery for power, and the other which can connect to my aux switch to turn it on. For those familiar with these, does that sound correct?
Can I connect both the pacbrake and the ARB to a single aux switch to turn them on? Would it beneficial to do so? I'm thinking it may run the compressor unnecessarily (or will it just power on but not actually run with no demand from the controller/ OBA QD) before the controller completes its power-on cycle and connects to my phone via bluetooth to tell the compressor to inflate my bags. At times I will just run the compressor as OBA.
I'd rather power both with one aux switch (even if the pacbrake isn't used) if it makes sense.
