The 6,4L Hemi was designed and tested with a specific oil which can be purchased at the dealership along with the filter. Many years ago I worked in a Tier 1 direct supplier (Siemens VDO) to the automotive industry and was involved in testing. I have visited companies such as Afton Chemical where oil additives are created and tested, and observed dynamometer testing at the same location, and visited their test tracks where vehicles with the same engines being tested on the dynos are run in real life.
If you believe for a second that a snake oil company like amsoil or redline has anything better to offer, you are wrong. Buy OEM and spend the extra $20 on an oil change for your $75k truck.
You are going to spend more than 20 extra dollars for redline or Amsoil. It’s not about saving money on either of them. It’s about a higher quality oil than what oem calls for. Not saying pennzoil isn’t a good quality oil but oils like redline have different additives added into them. Which the hemi needs. By no means is Amsoil or redline a snake oil. A simple internet search and you will find threads supporting it. Pennzoil works great for some but if you end up with a tick you will want something different like redline.The 6,4L Hemi was designed and tested with a specific oil which can be purchased at the dealership along with the filter. Many years ago I worked in a Tier 1 direct supplier (Siemens VDO) to the automotive industry and was involved in testing. I have visited companies such as Afton Chemical where oil additives are created and tested, and observed dynamometer testing at the same location, and visited their test tracks where vehicles with the same engines being tested on the dynos are run in real life.
There have been tons of discussions on this over the years, but IMO and in short - The modern Hemi has a sub-optimal oiling design for the cam/lifters. You can overcome this with a better AW add pack and avoiding things like excessive idling, but it's not uncommon to hear of Hemi's trashing the valve train. The most common one I hear of/see around here is the 5.7 in police vehicles that idle a ton and get changed with cheap bulk 5W20 - They're pretty well known for trashing the valvetrain. Behind that would be 6.4's in commercial applications where they've been idled way too much and the same cheapest "in-spec" bulk oil changes.You are going to spend more than 20 extra dollars for redline or Amsoil. It’s not about saving money on either of them. It’s about a higher quality oil than what oem calls for. Not saying pennzoil isn’t a good quality oil but oils like redline have different additives added into them. Which the hemi needs. By no means is Amsoil or redline a snake oil. A simple internet search and you will find threads supporting it. Pennzoil works great for some but if you end up with a tick you will want something different like redline.
Guys, I am a fact or fiction kind of guy and unless you are able to supply me with objective testing performed under controlled conditions which compare the various oils, in these specific engines, your replies are all just theories. Maybe they are true, maybe they are false, or maybe there is no statistical difference. I don't have time for a study such as this and I am not willing to risk the engine on my vehicle to "try something new and unproven."
I was driving south of San Antonio yesterday and would soon require an oil service - I called ahead to Chrysler Dodge Jeep Ram of Calallen in Corpus Christi, rolled in for service, and departed knowing I had the oil and filter my engine was designed and engineered to operate with. If you want to be the oil guy, cool. Me, I will travel, spent time exploring the forests and mountains, and meet buddies to watch big rockets shake the earth.
