Yesterday, I drove back to South Florida from Alabama. 710 miles, unloaded. Watching my gauges I saw the oil temperature climb to 205 and abruptly drop to 183, then start the slow climb to 205. Rinse, repeat for the entire drive. Coolant stayed constant at 187-190, transmission at 167.
I have never seen it do this before. It typically loads up to 10-15 degrees above the coolant temperature and stays there. I have read about the system not using an actual sensor. Have you seen this cycle in your truck, or does the oil temp stay constant?
