That is not normal. My 2019 6.4 uses no oil between 6000 mile changes.I've had my truck about a month and burned through a quart of oil in 3k miles. I noticed blue smoke this morning when starting. I have 3,400 miles on the truck. Not sure if this is normal or not.
Not normal at all. I'd take it in in a flash and have the dealer fix it under warranty. I'm at almost 10K miles with two oil changes and never lost a drop of oil.I've had my truck about a month and burned through a quart of oil in 3k miles. I noticed blue smoke this morning when starting. I have 3,400 miles on the truck. Not sure if this is normal or not.
My 22’ PW with the 6.4L used about a quart in the first 1000 miles. Now with 14,000 miles on the odo, it uses about a quart every 2500 miles. Time to bring the truck in
Yeah I have a feeling they might say that. Need to get a few other things looked at anyways. If they don’t do anything, atleast have it down on paper that I’m concerned about the oil consumptionGood luck getting them to do a thing about that, they will tell you its within the normal consumption range.
Don't let them pass this off as 'normal'. Losing 14.5% of your engine oil every 2500 miles is a sign that something is NOT normal. If the service rep says it is, ask him/her if they would accept their new 2022 +$55,000 truck losing that much oil as normal.My 22’ PW with the 6.4L used about a quart in the first 1000 miles. Now with 14,000 miles on the odo, it uses about a quart every 2500 miles. Time to bring the truck in
I don't see how they can say that's normal! Losing a quart every 2,500 miles is normal? I call BS on that. I've got over 16,000 miles on mine now, four oil changes (the first at 500 miles just 'cuz) without a perceptible loss of ANY oil.update- i took the truck in. They marked the fill/drain plug and dip stick then told me to drive 500 miles. After driven the truck 500 mile, i brought it back and they told me its normal .
Truck now has 18,900 miles.
