Lol yes sorry I’ll get a better pic tomorrow.WTH are we looking at? Winch?
Maybe zoom out for a pic of what it is...
lol the thought HAS crossed my mind.Sending your truck to the dealer for that??
Youre a braver man than me. Nope.. not a chance im giving those idiots my truck for a broken bolt.
I am going to wait till I have the new bolt to compare it to. To my eyes it is broken off flush with what I would imagine is the threaded hole itself but the new bolt will tell me for sure. If that is the case I am just going to leave the bridge on, center punch it and then work up from small drill bit to larger till I can get a decent extractor in the hole. Should turn itself right out with no other disassembly required.hard to tell from the photo is it broke off flush with the control box bridge or winch itself? how it is broke would determine how I would tackle it.
best way if it is like that is too get a rod the exact size of the hole (tight fit but not pound it in tight) and have a machine shop drill a 1/8" or so hole perfectly centered in the rod ie on a lathe and then use that as a pilot.....no chance of it getting all kitty wampus....I am going to wait till I have the new bolt to compare it to. To my eyes it is broken off flush with what I would imagine is the threaded hole itself but the new bolt will tell me for sure. If that is the case I am just going to leave the bridge on, center punch it and then work up from small drill bit to larger till I can get a decent extractor in the hole. Should turn itself right out with no other disassembly required.
Do you have any left handed drill bits? Or sharpen a bit backwards can usually get you by it will normally catch as you drill and the bolt will come right outI wonder how hard it is to just pull the bridge off in hopes of finding a nubbin to grab with some vice grips. Even if there isn't a nubbin centering the punch will be easier that way. I do like the drill bit idea - as long as its the same diameter. Even if its slightly smaller it would be darn close. I've usually used a tapered center punch that is slightly smaller than the hole when bottomed out - looking around the taper diameter inside the hole usually gets me lined up pretty darn good - kinda like a clutch disc alignment tool would.
I've got long extractors too.
Left handed drill bits scare me. I've had them "catch" as the bolt starts to back out, bolt snags on something and left handed bit shears off. Maybe I suck but I've had much better success with regular bits and a large (relative to the bolt) extractor instead. Then it gets seriously fun......Do you have any left handed drill bits? Or sharpen a bit backwards can usually get you by it will normally catch as you drill and the bolt will come right out
