Dang what issue are you seeing?I currently own my first and last set of ridge grapplers.
Interesting. Thanks for the insight on these. Never had an issue in snow or anything else. On a side note, Kentucky is beautiful man, I was through there last year and was in floored!You're the minority. Those are the worst tires on the market. They're expensive, loud, heavy, and the foul weather traction is s*it. My brother ran a set and by the time they were half worn they were dangerous on the road. He didn't even want to drive his truck in rain let alone snow. And over the years I have seen countless threads on forums where other guys have shared the same experience with them. They're just plain awful. Nitto tires in general have a hard rubber compound which is why they suck in foul weather. And, they can be hard to balance.
If you think those tires are good, you should try a tire that's good. Put a set of Falken A/T3W or Yokohama X-AT on your truck and it'll blow your mind.
Wxman post pretty much sums it up. Balance issues, wet traction and 30-35mph harmonics made me wish I went elsewhere. They look pretty dope thoDang what issue are you seeing?
Haven zero issues with my ridge grapplers. My truck rides quieter than my moms Mercedes. I hunt all winter in Idaho, mud, sand, snow, and ice and haven’t had any problems.
I just got my truck 2023 3500 DRW Limited HO 6.7 and will wait for the OEM to wear out. I did read Falken AT 3W was great tires. 235 80 17 , I am going to try 255 80 17 on stock OEM wheels.You're the minority. Those are the worst tires on the market. They're expensive, loud, heavy, and the foul weather traction is s*it. My brother ran a set and by the time they were half worn they were dangerous on the road. He didn't even want to drive his truck in rain let alone snow. And over the years I have seen countless threads on forums where other guys have shared the same experience with them. They're just plain awful. Nitto tires in general have a hard rubber compound which is why they suck in foul weather. And, they can be hard to balance.
I was gonna wait but no! The junk tires my truck came with caught some nails, one tire rapidly deflated and was ruined and another was slowly leaking, I swear they would get punctured hitting a porcupine!I just got my truck 2023 3500 DRW Limited HO 6.7 and will wait for the OEM to wear out. I did read Falken AT 3W was great tires. 235 80 17 , I am going to try 255 80 17 on stock OEM wheels.
What is 35 x 10.5 size tires in metric sizes? I see you have them on your original stock wheels? is that correct? Can I buy them at Discount tire shop? Do you need to lift the truck? Did you change the shocks?I was gonna wait but no! The junk tires my truck came with caught some nails, one tire rapidly deflated and was ruined and another was slowly leaking, I swear they would get punctured hitting a porcupine!
Good thing it happened when I was home, I've had an Arctic Ocean trip coming and was glad I've changed them to proper tires otherwise I would have been royally screwed if my tires blew while in that trip. For those who don't know, Dempster Highway that goes to the Arctic Ocean is nearly 600 miles long one way and it's all gravel.
I think you wanted to quote @gimmie11s post, correct?What is 35 x 10.5 size tires in metric sizes? I see you have them on your original stock wheels? is that correct? Can I buy them at Discount tire shop? Do you need to lift the truck? Did you change the shocks?
Understood. You are good on math. Thank you,I think you wanted to quote @gimmie11s post, correct?
I didn't need to lift nor add anything to run 35s, I went with 12.5 wide and they look awesome but would rub on a front sway bar at full lock in certain situations, 11.5 wouldn't have any rubbing. Mine is a SRW.
To convert to metric size:
10.5" would be the 1st number, in mm. = 266.7mm
35 - 17 (rim size) = 18" /2 = 9" = 228.6mm
228.6 / 266.7 = 85.7%
35x10.5R17 is 265/85R17
I am still 2 years away before my first tire change, but will be looking for possible two tire sizes.
1 - 255 80 17 - 10" wide x 33" tall
2 - 265 85 17 - 10.5 wide x 35" tall
I do like to stay with 17" stock rim.
