At zero miles the dealer would not take them, nor the tire store. I sold them as new take-offs to a rancher for $100 each.Any body have luck with getting the dealer to do a take off on the Nexen (POS) tires and install a good tire as part of the deal? Why is RAM so true to that brand? I had noting but trbl with seperations on 3 of 6!!!
Gives you an idea of the quality. U got a pretty good deal he gave you $100 a piece.At zero miles the dealer would not take them, nor the tire store. I sold them as new take-offs to a rancher for $100 each.
Sorry man - that sucks.2020 4WD DWR, 21K miles on factory installed Nexen Roadian HTX LT235/80/R17 all around. No discernible date codes on any of the Nexen tires. Tread separation on driver side front. Sidewall separation on passenger side, inside tire, inboard side. Happened while towing 18.5K+ 5W. Luckily we did not have a total blowout and crash. I will not be replacing those tires with like items. Maybe we hit something, but I do not recall going over anything in the road.
I checked the PSIs on all 12 tires prior to departure and all were at recommend (+/- 0.5 pound). IMMS, the rig sits around 20k when loaded (I don’t carry water or a genny), but I cannot recall what the tongue weight was last weigh-in. 20% of gross trailer is 4K on the hitch, which is well below the limits. I’ll take it back over the scales in the next 7-10 days and see where it is.Sorry man - that sucks.
Do you know what PSI you were running and have you ever weighed the rig on the scales?
I ask because according to the load chart, at max pressure (80 PSI) those fronts should be able to handle 3085 each (6170 on that axle) and as dualies in the rear 2835 each (or 11340 on that axle).
