What length come with our winch?The Harbor Freight ropes are plenty good. If you want to spend to get the best, Freedom Winch Line.
^^^ Everything he said. I took off the Warn Spydura line and put a Safe-Xtract line on mine. ASR sells Safe-Xtract. The line that comes on the Power Wagon is 80'. I put a 60' 7/16" line on. https://www.asroffroad.com/sx-20000a-winch-line-7-16-x-60-21-000-lb-mts/ I made the original winch line my extension.3/8” comes stock, recommended 7/16”. I think 80ft is stock, I wouldn’t go longer.
Long line seems useful on the surface, but you run a greater risk of stacking line on one side too high and damaging the winch. Plus, winch is stronger with less wraps…. Less line means you’re more likely to be on a wrap closer to the drum. Use an extension instead.
There are a lot of fine brands out there. But ASR offroad sells good, rigging quality stuff.
I also have the 7/16 Safe Xtract line. I haven’t had any issues with just the “hard dipped” loop, I just wedge it into the fairlead^^^ Everything he said. I took off the Warn Spydura line and put a Safe-Xtract line on mine. ASR sells Safe-Xtract. The line that comes on the Power Wagon is 80'. I put a 60' 7/16" line on. https://www.asroffroad.com/sx-20000a-winch-line-7-16-x-60-21-000-lb-mts/ I made the original winch line my extension.
As a side note, I was going to run it without using a hook to eliminate metal in the "closed loop" system. But, the first time I had to get the rope end off the storage hook on the fairlead while wearing gloves, I decided to put my Ultrahook back on.
