Yeasty McFlaps
- Joined
- May 4, 2021
Soot. Gd phoneYeah. It burns off the spot causing high DPF restriction. I get that part
How often is it regening? Mine seems like a lot, but if I go by engine hours it's only every 24 like a previous poster said. Also why add additives? Doubtful it would cause frequent regens, but still.Guys not to bring up older thread but this constant Regens is driving me crazy. I really don't think I do "too much city driving"....as I drive 25 miles one way on the interstate to get to and from work. Someone posted something about additives being burnt off in previous reply. Could me adding Hot Shots diesel additive be causing the constant regens?
I use Hot Shots and I only ever have the auto regens every 24 hours of engine use. My DPF gauge never moves.Guys not to bring up older thread but this constant Regens is driving me crazy. I really don't think I do "too much city driving"....as I drive 25 miles one way on the interstate to get to and from work. Someone posted something about additives being burnt off in previous reply. Could me adding Hot Shots diesel additive be causing the constant regens?
Elk how many engine hours do you have?
That's a short commute but it seems your average speed is pretty high for that, so it appears it's more highway, not stop and go. Short trips, stop and go, etc. may make it regen more often.I own a 2020 ram 2500. My average speed on my truck sits at 48.7 mph. I have a 35 mile commute to and from work. The route to work does have stoplights. My regens were around 1000 miles when I first got it. Then at 6000 miles the cp4 pump went out and I got the fixed (which they replaced all fuel injectors) and now I’m at 14000 miles and my regens are at about every 100-200 miles. I have taken it back to shop and they did a force regen on it and said that the whole dpf system checked out good and they said it clean now and should be good. However they never check on engine exhaust output. 200 miles later it regened again. This is the front end of our recreational as well and our only vehicle besides my bike. So it has to get me to and from work as well. On a guess does anybody think something is wrong with truck from the cp4 repair or do you think it is all just my driving style and if I hook up the camper and take it a drive it will clean it out better than a force regen. I am not mechanically talented by any means, Just working off of common sense. I’m wanting to take camper on a 800 mile trip, but worried if it a problem is coming off engine it will clog up filter that much faster while the camper is hooked.
I have 33k on mine and it's only did 2 or 3 regens at the 250 to 300 mile mark. Most all the time its 24 engine hours or 650 to 750 miles. I would definitely suspect a problem however the dealerships unfortunately are only trained for check engine code related problems. No codes no problem! Good luck resolving that bud. I feel for ya.I’ve had my truck for about a month now, just turned 1000 miles and it’s gone through 3 regens already. That seems pretty excessive to me, most of my driving to date is highway with some stop and go mixed in but one regen every 350 miles seems crazy!
