I got mine installed tonight.
For those looking to do this you’ll just need the torx 20 for the display, a 10 mm to disconnect the battery ground and an 8 mm to unscrew the screen module.
I’ll see more as I drive it but it looks like when you enable it locks the screen in the camera view. The X in the upper right corner doesn’t even take you out of that view. To get out, you hold the right center button behind the steering wheel (same button to enable). I didn’t test the turn signal operation to light up the cameras though. Not sure about that if it is automatic or not.
Took a couple pics to show the module behind the screen that you have to remove and I circled the connectors on the back. Then a picture after the module is installed.
I found it was better to work from the passenger side and it helps to disconnect the wire for the ACC outlet at the top of the dash. The rest you can leave connected.
