Lights on Steps
dieselscout80
Apr 23, 2022
I saw a picture here of a Ram with LEDs on the three mounts for the running boards/steps and I liked them. However, I can’t find it again to ask the owner about them. Does anyone know who it was are is the own still here?
They looked some what like 3/4” round LEDs.
I think if connected into both running lights and turn signal it would help when signaling for a turn.
Gear box
Dec 25, 2021
Not sure the round ones would have enough room behind the plastic cover and the hole would be larger. I used the truck lite 36 series dual function ,
36 Series, Dual-Function, Flex-Lite, LED, Rectangular, Yellow, 3 Diode, Black, 12V​
36203Y​
Also a trailer 2 bulb to single converter and the Y adapter at the receiver trailer plug trailer bulb converter so the brake signal doesn’t go to the new step lites. Think it ran about 300 in materials/lights. Post your pic when you get her done!
dieselscout80
Apr 23, 2022
36203Y​
Thanks and it looks good.
Is there a reason not to just tap into either the mirror or front running/turn signal, so a converter is not needed?
Gear box
Dec 25, 2021
I didn’t research that. Probably would be fine.
I started from front and worked back with splices jumped across behind fuel tank and to rear of truck.
dieselscout80
Apr 23, 2022
The below post show that the 3/4” round lights will work too.
3 wire version of the 3/4” LEDs lights.
Amazon link https://a.co/d/1dAJwoG
