You simply can't compare the BDS spacer lift to replacement coils. There is really no comparison in the ride quality. Spacers decrease ride quality, period. No matter what some guys claim.
Carli or Thuren replacement coils and shocks will make your front end ride like a half ton. It's that good. People are floored by how good my truck rides when they get in.
Spacers on an independent suspension mess with ride quality, there is no difference on a straight axle. No doubt that Carli springs are better than stock ride, but spacers are no different than stock. I have experience with both Carli and spacer lifts on my rams.You simply can't compare the BDS spacer lift to replacement coils. There is really no comparison in the ride quality. Spacers decrease ride quality, period. No matter what some guys claim.
I guess the bigger question is, what do you plan on doing with your truck? If you are going to do some serious off-road and jumping your truck then maybe you should get high strength components throughout. But if you’re like most I would get the lift you want and replace the other components as they wear which will likely take the good part of a 100,000 miles or more for many people. It’s easy to get sucked into purchasing the biggest best stuff that is out there. I did Carli with my last truck and honestly felt it was not worth it for me, but I only drive 20% of my time on fire roads and don’t do any serious off-roading, so I just never needed that kinda strength. This time around I did a zone leveling kit, the thing rides just fine and I still can tow at full capacity. I think you would be hard pressed to find someone that had trouble with bowed or worn out springs. I’ve seen trucks that have spent 200,000 plus miles on spacer leveling kits and their springs are just fine. It’s the big ol tires that wear everything out. Cheers man, hope you enjoy the truck.My biggest worry with spacers is that it'll cause a bow in the spring and just doing the shocks and springs will cause premature wear on the front end. I was just wondering if redoing the whole front end with the Carli front end would be the better option over doing the shocks and larger springs.
