Lets see your DRW with aftermarket wheels
Linked4door
Aug 26, 2020
Looking to get some ideas on possibly changing out my OEM wheels. Not sure what is out their with this new 8x200 bolt pattern and would like to see what y'all are running. Has anyone put a set of 19.5's on yet? Please post pics, and specs of the wheel/tire/suspension setup you have.
Ford has been running 8x200 since 95ish so there is a ton of wheel options….
Linked4door
Aug 26, 2020
The main reason is I really wanted to see wheels on our trucks to get a better idea what it would look like on a ram.
Appreciate that info about the fords sharing the same bolt pattern. Do you know if they shared the same size hub bore and backspacing?
I believe so but not 100% sure, i was not trying to say no need for pictures just about how there are lots of options which is nice
Drumminguy81
Oct 31, 2021
fuel triton 20x8.25 35-12.5-20 mud champs, stock suspension. -201 rear offset
maxx442
Jun 17, 2020
Colorado Springs
Did you use the Fuel D500 blank wheels with the +115 offset for the inners? If so, how much clearance do you have between the wheel and the suspension? I am assuming no spacers were used? Thanks.
Drumminguy81
Oct 31, 2021
Yes I used the fuel inners, no spacers there is about 3/4" between the tire and leaf in the rear.
Drumminguy81
Oct 31, 2021
Picked up a new set of shoes for the dually, got tired of the fuels and fell in love with this set, they are made by a small company customforged they do one off sets of custom machined forged dually wheels. This set is 22x8.25, I'm running 35x12.5r22 radar renegade at5 tires. So far I love the setup. 20230830_135124.jpg20230830_135142.jpg20230830_135148.jpg20230830_135157.jpg20230830_135117.jpg
cjames
Sep 22, 2023
Here’s mine with fuel blitz 20” on 37” STT pros. 2.5” leveling kit with 1” bag and 1” leaf spring blocks since I have auto bags.
Killer looking truck! Ive got the exact same on order and should be getting it in 2-3- weeks! What offset on the fronts? Looking to do the same and get rid of the dually adapters.
Scvette
Aug 15, 2021
If I remember right they’re -19, but not positive
phatboy64
Sep 20, 2022
I know I am going to sound like a broken record but 37’s really transform the look of these trucks…. Nice looking truck!
All 8 lug bolt Patterns are the same. Generally come on 3/4 ton and up trucks
No not right at all…. Since 99 ford has been 8x200 when most others were 8x165 now Ram has changed the 3500DRW to 8x200 while the SRW are 8x165. And typically only 3/4 and 1 tons are 8 bolt anything bigger is 10 bolt
