jadmt
2020 Power Wagon has under 9000 miles on it. getting ready to head out to go camping and truck is deader than a door nail. Never had an issue starting before. I jump start it and if fires right up but it will not shift out of park. check engine light is on. I light it run for 20 minutes or so and shut it off. It starts back up under its own power still won't shift into gear. let it run a while longer and shut it off again and let it set a few minutes and it starts and shifts into gear and check engine light stays on for the next 20 miles or so and two stop and starts and then goes off all seems fine. volts are reading 13.9-14.2V cruising down the road. end up driving about 150 miles to camp spot and everything seems normal. This morning jump into leave and dead battery again. Nothing is plugged in no accessories etc. My buddy jumps me and it runs fine and goes into gear no issue this time. Check engine light stays on until I get home and then after two starts goes out. I know batteries can go dead early but this seems really early. Truck does not sit for long periods of time and most trips are long enough not to abuse the battery. Nothing wired, no accessories etc
